·When I was converting from airbox to tpo beast it came with a bracket for the front cylinder coil. The vertical coil needs to be moved since I removed the side cover.
I'm thinking of moving both to a custom built bracket for both the coils and the rectifier under the seat.
Anyone have any problems with this idea?
I would need longer plug wire for the front plug, any wire suggestions?
