Any recommendations for an S2R? Possible to get a good pair of stands that would work for an S2R and later work for an 1198?
www.pit-bull.com , they aren't cheap but at least you can just buy the different diameter pins to accommodate any bike. Plus if you buy the front stand that lifts from the steering head it allows you to do a lot more front end work. I have a set of front and rear for my S4rs and I love em because they are totally stable when turning wrenches on the bike.
second on the pitbull. i have one for my 1100S and it is very stable. much easier & quicker to use than the excellent standard pitbull i have for the 696.
FYI- you will need a different pin for the 1098
on the front if you are using the stand that lifts the forks you should be fine, if the one that lifts from the triple, you may need an adapter for that as well
jeff h
monsterparts.com
