actually, stock sets off an st bike also fit. i'm running a set off an st4 currently. position is further back than stock but about same height.The only other stock OEM rearsets that will work on a Monster are from an 851/888. Those are rare and probably as expensive as buying aftermarket...
Supersport rearsets will fit, but the angle is exagerated to the rear quite a bit when fitted to the Monster frame and none of the people I know who have tried it (myself included) felt that they were a reasonable option.
HTH,
--Fillmore
He he he... I always forget that Ducati makes those. :actually, stock sets off an st bike also fit. i'm running a set off an st4 currently. position is further back than stock but about same height.
Have I mentioned how much I like the diamond plating on your bike strati? Might have to steal that idea... ;Dactually, stock sets off an st bike also fit. i'm running a set off an st4 currently. position is further back than stock but about same height.
I totally plan on stealling his idea. Strati, feel like giving us some insight on how you molded your diamond plate for the subframe?Have I mentioned how much I like the diamond plating on your bike strati? Might have to steal that idea... ;D
Yes please dont buy thoseThe only other stock OEM rearsets that will work on a Monster are from an 851/888. Those are rare and probably as expensive as buying aftermarket...
--Fillmore
