·Hello folks,
I have a 1999 750. I was wondering about the rear shock/suspension. I noticed the shrader valve at the top of the shock-is it possible to "charge" that thing with oil or gas-whichever the case may be.
I only weigh 165lbs (75 kilos) and sometimes the rear end "hits" a little hard over driveways and such.
The spring adjusters are already about as low as they can go, so I wondering if the shock just needs charging. Or even if it is possible.
The front could also use a little stiffer oil-but thats a later post.
Any help?
Any help?
