My stock rear fender snapped near the chain guide. This is a simple fix and I need advice on the propper glue to use.
Its called a hot knife and dremal. Mine broke the same way. I just cut the little wagging pick off leaving the part that bolts on the SA with a box cutter that I heated up with a little torch, then took my dremal for touch up. If you didn't know it was suppose to have something there you would never know.
