M
monsterdomo
·Guest
I recently installed new pads for the rear brake on my '99 M750 and the brakes don't seem to work too well. I lubed the back of the brake pads w/disc brake lubricant before installing them and I didn't bleed the brakes. I was taking a close look at the rotor and I noticed a couple small nicks on one side. Could the rotor be the source of the problem? Maybe I should've used a specific lube for the back of the pads instead of the stuff I used?
Any help/advice is greatly appreciated.
