I have an '00 M900s and am reassembling the rear brake and assembly.
On the S, the caliper sits at the bottom of the wheel and attached to a heim joint. The heim joint is on a rod, which then goes forward in the bike and attaches to a bracket. The bracket attaches to the bike through the bolts of the rearset.
Unfortunately for me, I didn't take good pictures of this whole assembly before I ripped it apart... Is it just as simple as bolting the heim joint on to the caliper and onto the bracket? Is there anythign special I should know (e.g. specific torque specs to use on the heim joint)?
Thanks,
Tigre
