sliding!Unsung said:What is a rear brake for?
Do you use it alot? If not, it might be a stuck caliper, causing alot of heat and possibly warping the rotor.CliveS2R said:how did it get warped?
i havent tipped the bike at all
Ain't that the one you use when goin' backwards ?Unsung said:What is a rear brake for?
If you lack a rear stand, grab a ruler and line it up across the rotor in a copuple of places. Taking the pads out too isn't that hard. Also, you can try and clean the spring retaining pins.xswimordiex said:like it's warped? if you have a rear stand, get the bike on it and spin the rear wheel with your hand and see if your brake rotor is warped.
