Ok I searched for this topic but couldn't find anything so sorry for beating a dead horse if this thread has previously been answered. I put Rizoma rear sets on my bike and had to get a longer hose connecting the resevoir to the banjo assembly. When I completed all of this I tried bleeding the brakes. I have done this numerous times on other bikes and have been successful but not this time. I haven't been able to build any pressure at all. Here are the steps I took.
1. Filled the resevoir
2. Loosen the bleeder valve and connect drain hose to bleeder valve
3.began to pump
4. Pumped until new fluid began to drain, as well as re filled resevoir as needed.
5. ONce new fluid began to drain, closed bleeder valve
6. Tested to see if brakes work
Result: no brake pressure at all.
What is the deal? Please help me figure out what I am doing wrong. Thanks
Patrick
3.began to pump
Patrick
