What is the torque spec for the rear axle in ft. lbs.?
M mwb · Registered Joined Feb 16, 2005 · 3,363 Posts Discussion Starter · #1 · Mar 16, 2004 Only show this user What is the torque spec for the rear axle in ft. lbs.?
G Guest · #2 · Mar 16, 2004 from http://www.ducati.com/bikes/tech.jhtml use the rear wheel nut spec for the ST bikes (same axle) and you get 83 Nm. anybody got a conversion?
S Speeddog · Registered Joined Feb 14, 2005 · 8,800 Posts #3 · Mar 16, 2004 Only show this user 1 N-m = 0.7376 ft-lb so 83 N-m = 61 ft-lb
M mwb · Registered Joined Feb 16, 2005 · 3,363 Posts Discussion Starter · #4 · Mar 16, 2004 Only show this user That is 61.2208. So, does 60 ft. lbs. sound about right?
S Speeddog · Registered Joined Feb 14, 2005 · 8,800 Posts #5 · Mar 16, 2004 Only show this user Close enough. Make sure to keep the socket completely engaged on the nut...dang thing is pretty thin. :-/
