i've been trying to find the bolt specification on the four bolts that holds the clamp down for the handlebar riser.
Four quantity. Hex head.
What i ultimately want to do is run a Ram mount ball through this.
Yes, i am aware that Ram makes one that grabs the bar also.
thanks.
227219
If I understand your post, you want a ball mount on top of the clamp bolt? Ram makes a ball kit that comes with a selection of bolt lengths. This is what I used on my Monster.
Also, you can find this same ball mount kit on Amazon, but they're knock-offs. The ball is metal, not rubber, even though the description states otherwise. Since the ball doesn’t compress, the mount arm won’t hold to the metal ball without moving. I returned the Amazon knockoff and bought the Ram.
correct, thats what i was asking. but to be specific, i was asking for the spec on that bolt as there are 50 different types. So the one i need is an "M8 by 55 or 65"?
