I have a shock with adjustable height (about .5"). Would like to increase ride height (Dark). Now normally I understand the suspension arch heims should be extended. However, given the suspension linkage on the Monster, I'm trying to understand if and how to raise both. It seems logical to me that I should raise both so the pivot rises "balanced". If I did only one, what effect would this have? If it's better to do one, which is it? For reference, I also intend on keeping the forks high enough to not change the balance between front and back by much. Advice appreciated.
