1 - 9 of 9 Posts
Went out for a ride in the rain tonight ('03 M800) - was quite heavy.
On the way home, I noticed that lcd instrument panel seemed to be water affected, and the numbers became hardly legible.
Anyone experienced this before?
I'll check to see if it dries out in the morning.
Small point, I know but would have thought these instruments to be waterproof?
To prevent starting another thread - while still in the same line of thinking...... anyone on this board taken apart the speedo / tach to fix anything in it like bulbs, seals, or glue the tach panel back up?
The reason I ask is that I just noticed the bottom side of the tach is coming off whatever it is stuck to (surprising right - because Ducati seems to use the best adhesives going - like for the mirrors). I was going to take it off this weekend, disconnet the two (I think there are only two) sets of wire going into the back and taking the thing apart to glue the tach back.
I wanted to ask this because I want to avoid any unforeseen issues that other people might have run into while re-water tightening or servicing those buggers that may be outside of their warranty period. It should be straight forward - but who knows?
Just to state an obvious thing here. I used to get a little water in my gauges before I mounted a windscreen. The water was likely getting in from the driving force of the rain combined with a moving bike. Since I added the windscreen not a drop (and I have ridden in some crazy rain storms since).... They are the old analog style gauges (for what it is worth).
The instruments on my '03 M100S get foggy after rain. I tried to improve the seal where the cable harness jacks in, which seemed to be the obvious place for water to leak in.
I used bicycle tire tube and some cable ties. No 100% but definately better now.
P.S> I have this problem wether I am using my screen or not. :-/
1 - 9 of 9 Posts
