I am taking my rear brake pads out and I cannot get the pin in the caliper out. There is a ring on the pin that is holding the pads in and I cannot remove that little ring.
What am I doing wrong??
I had trouble with mine too. I noticed that you pulled the caliper before removing the pads. I find it easier to pull the pads while the caliper is still mounted. Are the pads touching each other? If so, try bleeding a little pressure off so they wiggle around easier. And then you may have to hold your tongue just right..........
