1 - 14 of 14 Posts
Question about velocity stacks and airbox mods:
So I used to have a Ninja 1000 (not a ZX-10). That thing had a sick intake howl and with an airbox mod it was even meaner sounding. Last night on the forums I saw a discussion about an airbox mod for the S2R/S4R. The poster mentioned that Ducati had designed the airbox to be quiet rather than for higher performance.
I have no idea if this is true or not, but has anyone heard of this or tried modding the airbox or adding velocity stacks??
Would either or both of these result in any measurable benefit?
Even if there is no HP/Torque change, Would modding the airbox increase the intake howl?
If there are other references to this in the forums please feel free to point me in that direction, I didn't find any results about this typic that were specific to the 1200 when I was searching.
Super Moderator
Airbox mods are not uncommon for Ducatis. Ducati people seem to delight in spending money.
I have heard from several sources that velocity stacks are a great upgrade for HyperMotards, and really do make a difference there.
My personal inclination is not to change much, and not to fix things that aren't broken, so I'm still running the stock setup for my M900.
YMMV.
PhilB
It certainly could increase the howl depending on what you do to it or by replacing it with velocity stacks.
FWIW, I used to believe that more howl was positively correlated with increased flow. I don't believe this any longer as both may be completely un-correlated.
You may also be damaging your engine in the process for little in return. Also: unclogging the exhaust produces more air-intake as a by-product.
As stated by @philb...if it ain't broke...
Discussion Starter #4
Thank you for the replies, I already have the headers and can but haven't installed them yet - waiting for the tuner currently.
@digitalnico
Wow, you're going for the full nine yards with the headers. Are they Titanium? I have purchased a slip-on that is yet to be installed and will remove the butterfly valve if I can find a skilled welder to plug-up the holes and adding a fuel controller. In the absence of a good welder, I'll just settle by disconnecting the servo and cable. That's as far as I'm willing to go. What do you mean by "waiting for a tuner?" Do you mean an actual person or a fuel controller?
Modern air boxes are made to flow as close to what the stock engine needs as the factory is able while keeping intake noise down. If you do mods to other areas to increase performance you will probably benefit from decreased restriction from the intake side. A low restriction filter element may not help on its own if the air box design is restrictive. If you are changing the exhaust and tuning anyway, it would be the right time to increase the airbox flow . I'm sure if you check the forums you'll see examples of air box mods. A high flow filter is subject to debate because decreased filtration is usually the trade off, but at least some of them are washable. Think of where rain will likely flow in, taking wind into consideration. Don't bore holes that will suck rain in. Internal air box baffling is a sound reduction thing and it's usually beneficial to remove it. I'll bet there are videos on line showing what to do on your model. I just googled problems I was having with two different older bikes today and had multiple solutions on both, with pics, videos, parts sources and part numbers . What more could I ask for ? It saved me hours.
Discussion Starter #7
@DarR
Yes, I bought the titanium Akra headers and an SC project CRT can. I am waiting for my tax return to come back before buying a Rapid Bike EVO tuner and hi-flow air filter.
Take this with a small grain of salt, but the master mechanic at my dealership and I were having a beer and talking 'for-funzies-mods' with my 1200. He said 1098 cams can drop right in and would net a huge HP increase. He also said (use a bigger grain of salt here) that with enough time and money this engine can make 205 hp. To which my response was O.O .... I would have to stitch myself to the seat to stay on. I'm thinking I could push it to 180 HP optimistically with cams and all. We'll see what happens with time but I havent seen anyone near those numbers so far.
The headers, tuner and can will be installed in the next 2 weeks or so. Then its going to be some protection mods, frame sliders and rad guards. then I'll be broke again :) -.-
@DarR
well, given 1198's made 180bhp stock I would think 205bhp in World Superbike trim would be likely. In my experience mechanics like to talk of ten tenths possibilities and handily ignore if the motor will last more than 20k miles. ;)
Hi Sonic Duck,
you say that 1198's stock gave 180hp? To my knowledge that was 160 hp for the older ones and 170 for the later. My 2009 1198S (160ph) was software tuned with full Akrapovic to 175hp
My Monster 1200 (no S) has been fitted with 1198 pistons, clutch and cam and now produces 171 hp at 9200 rpm (all @CLUTCH).
Especially around 3000-4000 rpm it is stronger and smoother than the 1198
Limitations of a Monster 1200 compared to an 1198 however are, as I understood from a specialist:
- airbox of an 1198 is less restrictive and will always give more possibilities for enhancement
- the intake diameter as well as the injection (throttle bodies) of an 1198 allow for more power
Nevertheless: comparing a 205hp Panigale 1299 power curve with my Monster 1200 learns that:
- at 7700 rpm the Panigale and my Monster are equally strong (140 hp at the clutch)
- above that RPM the Panigale maganes to gain an extra 65 hp when allowed to go to 10500 rpm, mine only an extra 31 hp (171) at 9200 rpm
- below that rpm my Monster has up to 20% MORE torque than the Panigale, mostly around 15% and without the torque dip that the Panigale does have. (you need to go all the way up to 6700 rpm only to regain the torque it has at 4000 rpm, which is 13% below the torque the Monster has at 4000 rpm anyway!
I don't know about you, but I mostly ride it below 8000 rpm and enjoy the almost flat torque curve of 125-133 nm (92-98 lb.ft) between 3700 and 8500 rpm.
I really have no need to find more top end hp as it will surely cost torque and thus hp at lower and midrange revs.
Maybe thanks to the smaller throttle bodies and airbox my Monster is so much better at the rev ranges you mostly use.
Apart from these differences, both the 1200 and Panigale engines are infamous for costly engine failures in continuous race use.
The prolonged rpm's tend to stress these massive pistons to and beyond the limit ... an other reason to love power at lower revs.
I'd take that comment with a salt mine :laugh
HP is a product of RPM and the Testastretta engine doesn't spin as fast as a Superquadro.
Now the Superquadro has been superseded with the Desmosedici engine in the V4 for the same reason.
i dont know how i wound up in this section as i dont own a newer monster, but to answer the OP question, i dont think you have much of a "mod" to the airbox available to you as those bikes have the weird tube air filter. im sure freeing that up will cause your induction noise to go up, but not like an inline 4 on ITBs and stacks
that being said, the induction noise from my S4RS with TPO velocity stacks, a Pipercross filter and HSBK carbon airbox(open) literally causes pain in your ears/head and sometimes causes chest pain and blurred vision. its a lot cooler in theory than in practice. a tucked high load pull in 1-2-3 will often feel like your head is in a vice and cause your vision to go blurry. i have no idea why, and this isnt just me. i have had other people ask me how/why it does that. also, im not sensitive to noise, i spend my days surrounded by heavy equipment and have a VERY powerful stereo in my car.
I did this when having a honda fireblade, velocity stack mod was a simple buy the stacks saw them in half (down the centre) and join them together as then you ended up with 2 short stacks. was much cheaper then buying the HRC spec ones.
Difference meh wouldn't do it again, if bored then go for your life. Put it this way if you think howl is there put your ears out and see if you can hear the difference with someone whom has done the mod.. 9/10 you won't know the difference. power lucky to be 2%
1 - 14 of 14 Posts
