1 - 20 of 23 Posts
That's just a cover. Install literally takes 30 seconds. It's just a small box that plugs into where the exhaust flapper motor plugs into the bikes harness. If you're wanting to get rid of the entire pipe assembly u need to find a 696 mod pipe since they didn't come with the flapper.
I've seen a couple places where it said the 796 doesn't have the butterfly valve, but I hear the servo motor, so it does right? I just got mine. 2014, and ultimately looking to help the twitchy throttle response. Does the Duc EE help that, and or what other benefits does it have?
It does. Look at the 696's. They dont have it and their midpipe is just a straight pipe. The 796's and 1100's do. It closes at high rpm's to limit noise to meet local regulations. The servo eliminator tool gives someone the ability to remove the servo without getting an error or check engine light. Removing the servo eliminates weight, makes the bike louder and in theory increases performance because there is better flow at high rpm. I could be mistaken but i dont think the flapper is closed at lower rpms in order to decrease unwanted back pressure from having too much flow.
Discussion Starter #7
I installed mine and it did smoothen out the bike a little. But so far the best mod I have done is changing the front sprocket to 14t. Bike is much smoother and much easier taking off
IraceDM, PM sent.
How would I go about removing the exhaust valve on my 796? I have the carbon Termi slip-ons installed (I think these came with a new ECU as well?). Do I need to do an ECU flash or buy a Duc.EE? Any hardware need to be removed or just a software change? What benefits would I receive from doing this? Thanks all for the help!!
You've got a couple of options. You can remove the cable from the valve which will keep the valve open. From what I've read, this will not throw a CEL. You can also pick up a Duc.EE and plug it into the servo harness. This will keep the valve open and trick the bike into thinking the servo still works correctly and keep the CEL from popping up. Or you can buy a midpipe from a 696 to remove the valve entirely and add the Duc.EE to keep the CEL off.
Here are the instructions from their website. Really straight forward.
Thanks for your input guys! I simply pulled the cable under that piece of plastic, leaves the servo and such, but leaves the butterfly in the open position as well. This alone gave me the benefits I was looking for from this mod - little smoother, little louder. I just added the 14 tooth sprocket this weekend as well which, I concur, was far more beneficial and impactful :)
Is this all I need? Plug and play and the servo will stay open? I can then remove the valve down the line if need be?
Yea the price has been $55-59 for a while. Like many others, I paid $150 two years ago for the same product. Supply and demand changed and/or a new parts supplier.
Wanted to add to this older thread - others may be currently interested in this mod, as I was. Installed on my 2013 796 ABS, took about ten minutes.
Removed cable to the flapper as well as the underseat servo. Completely plug n play with the Duc.EE from Vizi-Tec. Small and easy to find a spot for it.
The bike has run fine since new. It could be my imagination but now seems to run smoother in the 4K to 5K rpm range. Before the mod 4K was the sweet spot for cruising, now it is happy to 5K.
The sound quality is different down low as well, hard to put my finger on it but somehow better...
Quick question regarding longer term useage/lifespan of this module.
I've had mine now for 4yrs+ and recently its started playing up. In the past it would throw the occasional CEL with the exhaust valve code, I would have to unplug the module, replug it in and its good again for 12months+. Now the last couple weeks its been popping up about 7/10 times. I've removed, checked the pins and plugs, replugged, wiggled wires, re-routed the module and wiring but it seems to be unaffected by this.
I have found that I have to turn the bike off then turn on and wait if the CEL turns off, If not then turn key off, turn on and check again.
Anyone have any ideas about this or heard of anything similar?
Mik, not sure what brand your part is, but Bernard over at Vizi-Tec has been super helpful with my duc.ee as well as my brake light flasher. He's a Ducati guy and might have some thoughts. Keep us posted, throwing codes is a nightmare you would like to wake up from.
1 - 20 of 23 Posts
