Is it very hard to replace the pressure plate? I've seen some nice colored ones that look great behind a vented clutch cover.
Discussion Starter · #2 ·
No. Remove cover; remove 6 screws/springs in a cross-wise pattern like when you remove a wheel on your car; remove old plate; (assuming pushrod stayed in place and the new PP has a bearing installed) remove pushrod cap from old PP; install pushrod cap in new PP; install new PP aligning to marks on screw post; gently tighten springs and screws. Done.
