Ok guys & gals, if you remember my last new topic, i found this.
Doing this.
I finally managed to gather up all the nessecary bits to start reassembly. I started by replacing the pressure plate bolts (all of them). That's when i realized i didn't know what to torque them to. No problem, i'll just hop onto the DML and do a search. I've read 4 pages of results and got anywhere from 4 to 18 ft lbs. So here is what i did:
1- snug screws with fingers
2- use torque wrench to apply just enough pressure to cause clutch to start to rotate (needle at approx 8 ft lbs)
Will this be good enough or do i need to apply silicone to the threads?
I don't want to have another one back out, the engine cover can't take much more whittling.
I just can't help thinking they should be tighter.
Doing this.
