Just got back from a 75 mile ride and noticed some motor oil pooled up over the top of the transmission behind the vertical cylinder head (2002 620) (actually, I noticed the smoke from the oil, which prompted me to look...)
I'm not sure if it's from the gasket, or the breather. Here are some pics:
Any ideas? I'm not too concerned with leaking oil per se, unless it leaks on the track of my rear wheel and makes me fall...
Can the breather leak that much oil in one ride? it was all over the bottom of the trans. casing and on the exhaust pipe as well... (that's where the smoke came from). Did a search and I see that it's sort of a common problem. I cleaned it all off and will see how bad it's leaking while sitting/running.
