1 - 8 of 8 Posts
· Registered
Yesterday I rode my m600 2001 for 2 hours.then took a gas from gas station out of the town.After that bike started poping,especially When I was off the throttle while down shifting.Today I changed a gas with new one-still poping.I checked carburator if I didn't lose mixture screw or something,checked spark plugs-o.k.so if anybody knows what can be cause please some advice.
· Registered
Is your bike running normally otherwise?
Idle speed and quality are OK?
Do you have the stock exhaust on the bike? If it's aftermarket you could have a small exhaust leak where the slip-ons..er...slip on.
Even if you have the stock cans, make sure they are seated and tightened down.
· Registered
yes,bike's running o.k.idle speed is o.k too.I already checked for air leaking.I have got stock exhaust-o.k.does anybody know what mixture adjusting is for m600 2001?I have 3 turns out.
My 2001 m600 mixture screws are turned out 4 turns. I also put in some hotter plugs NGK DR8EAs I think and that relieved my popping problem.
1 - 8 of 8 Posts
