I finally got everything stripped down to split the cases on the Monster's motor except the primary gear. I own almost every other tool imaginable except a gear puller.
So first thing this morning I hop over to Sears and get a 2 jaw/5 ton puller because a 3 jaw won't fit around the primary gear.
I've wrenched on stuff for almost 40 years and have used pullers before, so the fine print warning in the instructions about not standing in front of the puller wasn't news to me.
Let me warn you - when pulling the primary gear on a 900 motor, not only must you not stand in harms way, but make sure there is a clear path for about 15 ft or more in the direction of pull.
I had to use a regular 1/2 inch breaker bar to turn the puller. And when it finally yielded, the gear and the puller cleared a path across the garage and ended up with the puller rebounding off the compressor tank and the gear ending up between the compressor and the wall.
Sounded like a small cannon going off.
I'm glad I didn't leave the nut partially on the shaft to catch everything, as it would probably have buggered or torn the threads right off the shaft when the gear let go.
Work safe, ya'll.
Work safe, ya'll.
