If you have a 2002 and probably up Monster your pipes are not like those shown on Ducati suite. I went to core my pipes today and found out that there is no baffling inside at all. It has a honeycomb thing in the bottom of the pipe that goes into two pipes. One small one big. The small pipe feeds into a chamber which has another pipe that feeds through the second wall with the larger pipe mentioned before. I cut my pipes down to 9 1/2 inches from the back of the aluminum shell to the front. I don't know if this will give me the desired affect, but we will see.
Just in case, does any body have a set up stock pipes they are willing to let go. If so PM me. Thanks...
