Come on yuu. When the "prior owner" is telling you all about the bike you're about to buy, you should listen. [laugh]yuu said:I didn't cut it - the prior owner of my 900 had the cover cut by a machinest buddy.
If I were to do it - I'd rough cut with a dremel and then use a file to nice up the lines.
Polishing stuffs pretty simple
that looks ****ing fantasticyuu said:Cut and polished stock, prior to powder coat.
You can check it out in person at some point.
