· Premium Member
Anyone know what the difference is between the PCII and III?
Also, when you install a PCIII how does it work? It doesn't replace the stock ECU right it just plugs in series with it?
· Registered
The PCIII has a self correction program to optimize the mapping when you are mapping it on the dyno, whereas the PCII has to be adjusted manually (on the computer one grid at a time) and then ran on the dyno again to check the results. Also the PCIII carries an option to adjust ingnition timing.
· Registered
As far as I've found out, the PCIII only has ignition timing control for some bikes, and Ducati is not one of 'em.
I think your only option for an S4 is a PCIII.
