1 - 9 of 9 Posts
I recently picked up a wrecked 2013 Monster 696 ABS (black) that surprisingly was not totaled by the liability insurance company who insured the party at fault (auto driver). The seller had no insurance. It has a minor frame dent, bent bars, and the usual cosmetic damage (fender, seat cushion, etc.) but worst of all (discovered after I bought, amatuer mistake), the kickstand was out of whack and turns out it ripped out of the housing that is part of the engine case. Tried to tap a 2mm larger bolt (12mm) and was successful in grabbing about a 1/2" of thread but it wasn't enough. bottom line is the engine case needs to be replaced. Anyway, I got into the deal knowing it may involve too much to get it up and running again so plan B was to part it out. So here I am.
Wanted to give forum members a heads up before I start listing things on ebay.
In summary here is what looks good (among many other smaller things):
Front and rear wheels with new Dunlops just put on before wreck.
Brake calipers look good
Swingarm good
Dash fires up but throws "wrench" warning light (12k miles on bike)
Battery fully charges
Engine all fine except case on kickstand side and clutch cover cracked
Right side tank cover damaged but repairable. Left side fine.
Engine good for lots of parts.
Tank good
Shock good
Stock exhausts good (weren't on bike) as well as center pipe (fork portion that attaches to cans)
Lots of other stuff good
I'll post pics tomorrow but hit me up if you need anything and throw me an offer.
I'm in Clearwater, FL
Discussion Starter #4 (Edited)
Here is what I have so far... (figures after description are asking PRICE and SHIPPING
Handle Bar Riser Clamp and Base 144.95 10.5
Stock Exhaust Silencer Set Right and Left 109 39
Exhaust Pipe Center Piece OEM 40 35
Left Mirror OEM 55 5
Rear Mudguard and Chain Guard Black OEM 43 15
Front and Rear Tank Cover OEM Black 32 5
Fuel Tank 95 50
Front Sprocket Chain Pinion Cover Guard 11.99 5
Ignition Coil Set of 2 with Plug Wires Cables Included 45 5
ECU Engine Control Unit 89 0
Voltage Regulator Rectifier 75 0
Starter Relay Solenoid with cables 25 5
ABS Control Unit 139 10
Fuel Pump Assembly 78 10
Front Wheel ABS Sensor and Holder Bracket 44 7
Air Filter Box and Air Filter Case Cover and Cage 95 15
Horn 12 0
Main Wiring Harness - No damaged connectors or cut wires 139 0
Main Switch with Key and Fuel Tank Cap Set 89 7
Left Handle Switch and Starter Choke Cable 69 7
Clutch Master Cylinder with Line and Lever 69 7
Left Front Brake Caliper and almost new EBC Pads 95 7
Rear Brake Caliper and Pads 75 7
Throttle Control Cable Transmission Line 19 7
Other items not disassembled but will be within a week....
Front and Rear Wheels with rotors and NEW Dunlop Tires on each .. perfect condition
FRAME WITH TITLE - minor dent.. insurance company did not total
Subframe - Complete
Swingarm
Front Fork - Suspension System - Complete with triple tree - Perfectly Straight (Tested)
Stock HandleBar Risers
Left side footpeg mount (OEM Rearset) with both driver and passenger footpegs
Electronic Dash
Throttle Body - Complete
Engine - with damaged case on left (from kickstand impact) and damaged clutch cover
Kickstand and sensor
15 tooth OEM sprocket
OEM rear shock
IF interested in anything please message me and I can send pictures.
How much for the complete rear swingarm with wheels? Maybe the complete front end with triple tree and wheel also. I have been shopping around on eBay for awhile now but still haven't found a deal I like on the swingarm. Also can you confirm the maximum width the swingarm is if the pivot bolt spacers are moved to their widest position where it mounts onto the frame? I am looking for a swingarm that is right at 6" wide at the opening to be an easy conversion for my cafe racer. Let me know what kind of a package deal you would like to make, I am in Everett, WA 98204. Thanks,
Discussion Starter #6
Here is what I still have left with price drops.. (figures after description are asking PRICE and SHIPPING
Stock Exhaust Silencer Set Right and Left 79 39
Left Mirror OEM 39 5
Rear Mudguard and Chain Guard Black OEM 32 15
Front and Rear Tank Cover OEM Black 25 5
Fuel Tank 69 50
Throttle control cable 19 3
Front Sprocket Chain Pinion Cover Guard 12 5
Ignition Coil Set of 2 with Plug Wires Cables Included 40 5
ECU Engine Control Unit 69 7
Starter Relay Solenoid with cables 20 5
ABS Control Unit 75 10
Fuel Pump Assembly 69 10
Horn 12 0
Main Wiring Harness - No damaged connectors or cut wires 70 10
Left Handle Switch and Starter Choke Cable 49 7
Left Front Brake Caliper and almost new EBC Pads 75 7
Rear Brake Caliper and Pads 55 7
Rear Brake Caliper mount bracket with ABS Sensor 45 7
Front Wheel with new Dunlops and Rotors (black) - no damage 225 60
Rear Wheel with ne Dunlops and Rotor (black) - no damage 225 60
Rear Wheel Axle Spindle 59 12
FRAME WITH TITLE - minor dent.. insurance company did not total MAKE OFFER
Subframe with Tail piece 79 40
Swingarm 79 50
Front Fork - Suspension System - Complete with triple tree - Perfectly Straight (Tested) - MAKE OFFER
Left side footpeg mount (OEM Rearset) with both driver and passenger footpegs 69 15
Throttle Body - Complete 79 12
Engine - with damaged case on left (from kickstand impact) and damaged clutch cover - 550 125
15 tooth OEM sprocket 19 0
OEM rear shock 59 25
IF interested PM me and i can send pictures too.
1 - 9 of 9 Posts
