1 - 11 of 11 Posts
I have posted pictures in my garage of a 1997 Ducati 748 that I am parting out.
Please let me know if you would be interested in anything.
Kevin
I also have a price list - it's not complete - but has most of the main items:
1997 Ducati 748 Superbike
Part Description Price to Pick up Part Condition of Part Status
Complete Engine Top End is good - Pistal Big Bore Kit - 853cc, all new followers $400 Top End - Like New
Complete Frame Never wrecked - Clear Title $450 Good Pending
Wheels & Tires - Front & Rear Black Powdercoated, Pierelli Diablo Super Corsa - 1,000 miles $400 Like New
Wheels - Extra Set OEM Gold $200 Good
Rear Wheel Hub & Spindle $100 Good Pending
Front Brembo Rotors & Pads EBC Extreme Pro $200 Good Sold
Front Brembo Calipers $200 Good
Rear Brembo Rotor & Pads EBC Extreme Pro $100 Good
Rear Brembo Caliper $50 Good
Galfner SS Front and Rear Brake Lines 58cycle.com $50 Like New
Front & Rear Sprocket & Chain Sprocket Center 520 Chain Kit, Quick Change Sprocket $200 Like New
STM Slipper Clutch 1,000 miles $400 Like New
Forks Rebuilt with Race-tech internals - 1,000 miles $300 Good
Rear Shock Rebuilt with Race-tech internals - 1,000 miles $150 Good
Steering Damper Stock $40 Good
Gas Tank Stock with Tank protector, No Dents or Scratches $300 Good Sold
Fuel Pump Stock $200 Good
Radiator with electric fan Stock $150 Good
Radiator Hoses & clamps Black Samco - Silicon less than 500 miles $125 Like New
Coolant Expansion Tanks Stock $30 Good
Power Commander III DynoJet USB $200 Like New
Termignoni Full Exhaust Black Ceramic Coated $500 Like New
ECU Updated with Exhaust $200 Good
Timing Belt Covers Stock $75 Good
Timing Belts 1,000 miles $25 Like New
Speedo Cluster Stock - everything works $250 Good
Starter Stock $70 Good
Battery New Yusa always on tender less than 400 miles $40 Like New Pending
Battery Tray Stock $40 Fair
Voltage Regulator $100 Good
Ignition / One Key Stock $100 Good
Main Engine Control Wiring Harness $100 Good
Engine control unit $100 Good
Xenon Headlight Bulb Kit Updated 1,000 miles $50 Like New Pending
Headlight Wiring Harness $50 Good
Stator Stock $30 Good
Corbin seat & Mono Tailpiece $200 Good
Tailights with signals $50 Good
License plate bracket and holder Tail Tidy Rear Fender Eliminator $30 Good
Mirrors Moto-Science- Carbon LED $75 Like New
Front Fender Aftermarket $50 Good
Chin fairing Aftermarket $20 Fair
Front Nose Fairing Piece $50 Good Pending
Zero Gravity Dark Windscreen Sold
Kill Switch Sold
Fairings Original Original bought for spares - some light damage $200 Fair
Fairings Xerox Aftermarket - some cracks $100 Fair
Carbon Fiber Rear Hugger/Chain Guard, Exhaust Cover,Heel Plates and Clutch cover $125 Good
Airbox Intake and Fairing Stock - has a crack that was siliconed $100 Fair
Airbox Filters Stock $25 Good
CRG Levers - Clutch & Brake Aftermarket like new $100 Like New
Ducat Breather Valve $40 Like New
Helibars $150 Like New
OEM Rear Sets Stock $30 Good
OEM Shifter Stock $30 Good
OEM brake pedal Stock $30 Good
Kickstand Aftermarket - selfretracting $50 Good
Triple Tree Upper and Lower $100 Good
Slave cylinder $50 Good
Discussion Starter #5
If you are talking about the number of notches around the diameter - there are 48. I will post a pic in my garage if there is room
KL
Discussion Starter #9
I have a guy who is supposed to be buying them this saturday. As with everything, it's all first come (with cash) first served (with parts).
I can let you know if the other guy backs out.
In my opinion, If you're still in Houston, TX it probably will not be worth the cost of shipping for you.
Kevin
1 - 11 of 11 Posts
