Hi,
I am looking to replace my gas tank on my 2000 ducati 750 monster. Does anyone know what other ducati tanks will fit? i.e. 999, SR4, etc...
I am also wanting to swap out my forks and triple clamp, does anyone know which ones will work on my model?
I am also wanting to swap out my rear swingarm and wheel, does anyone know which ones will work on my model?
Thanks,
Alvin
Thanks, I tried searching before but didn't have much luck. I will try to look harder in the future.
Thanks,
3rive
This is only your second post, so I will assume you just joined and have not even looked throught the site. Note that there is a search button on top on the formus, a little judicious use would have led you to this link, which discusses which tanks fit which Duc's.
Spend a little time cruising this site, it has a wealth of information readily available.
http://www.ducatimonster.org/forums/tech/144663-faq-fuel-tanks-diff-specs-years-models-etc.html
I just recently joined this forum as well and have been quietly lurking trying to read up on all the posts that interest me and I believe their to be a lack of quality posts pertaining to DIY maintenance and modification. The posts that do exsist almost always lack photos which is very frustrating.
My suggestion would to be have a sticky in the FAQ section containing 'threads of note' as I'm sure the OP's question as well as a couple dozen others come up time and time again.
my .02
