Guys. Thanks very much for your replys on my oil pressure light. I am going to Clean and protect the sensor from humidity.
But...Which one is the oil pressure sensor. I don't have a book. I See several different possibilities.
1. Is it the sensor directly above the oil fill cap on the right side that snaps off?
2. If it the sensor that is on the right/ top that taps into the front cyliynder?
3. Is it the sensor on the left top that simply has a nut on either side.
4. or is it the sensor on the left side gear box that has a hex nut on either side which slides out and is about 1 1/2" long?
Thanks again guys!!! When I learn more i hope to help the newbies.
Dummy Dan
On my 95 900, the oil sensor is just forward and above the oil fill cap. The wire has a little spring clip that has to be squeezed to get the connector off the sensor.
