Welcome to the board.0jess said:Can anyone recommend a good oil pressure gauge to replace the factory sending unit on my '98 M600?
PM hiero on the board. He had to make an adapter for his due to a stripped thread issue. I'm sure he could tell you what the thread is.0jess said:Yeah, an actual gauge on the side cover, chopper style. I've seen some for older Jap bikes that would probably work, just not sure of threads, adapters, etc.
not bad for $15 [thumbsup]Desmo Stu said:I have this one and it works sweeeet! [thumbsup]
http://cgi.ebay.com/ebaymotors/NEW-...ryZ35557QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
thanks for the shout DP [thumbsup]ducpainter said:PM hiero on the board. He had to make an adapter for his due to a stripped thread issue. I'm sure he could tell you what the thread is.
[thumbsup]0jess said:Went w/ the $15 ebay special, applied a little hi-tack to the threads, screwed it right in. perfect fit. Screw the factory sending unit, wires are bad. >![]()
yes i do have a replacement temp gauge that fits into excisting oil fill cap thus keeping your oil light !! looks trick!!! 8) more after christmas,slowduc said:not bad for $15 [thumbsup]
does anyone know if there's a relatively simple way to use something like this on the "ie" bikes and still keep the oil pressure idiot light working on the stock gauge cluster? it would be nice to have a way to see the oil pressure all the time rather than removing the stock sensor to check the pressure during maintenance intervals, AND still have the idiot light come on if sumpthin's wrong![]()
