I have a slight oil leak in the crankcase cover. Changed the cover with the speedy-moto one that also includes a new gasket and it still leaks. Any advice on these matter? Is this a common leak? Thanks!!!!
Are you sure it's from the cover? I've had a cylinder head leak that managed to look like a cover leak.
Normally refitting with liquid gasket will solve it. I don't use a torque wrench for fitting, just a allen key and not much force.
