So my monster sprung a pretty bad leak today. Oil is coming from behind the front sprocket. I assume it is a broken seal or the bearing went bad. Any advice? Also what parts do i need and where is the best place to get them? Thanks
I've never had one leak, but there is a bearing and a seal behind the case and.........you guessed it, you'll have to split the cases to get to it. Any of the online dealers can get the part, check with a few of the sponsers here.
might also check that the oil isnt coming from further up and is just ending up in that area
(and double check its not brake fluid fom the clutch slave...)
Ok i'll check but i'm pretty sure its that seal. Am i going to have to pull the motor to fix this? and what is that bearing/seal (which is it) called? (dumb question but i don't know what to call it)
