This is a nice one:
CORSE DYNAMICS Magnetic Oil Drain Plug V2: 22mm
$18.95
•"double hex" design allows you to remove or install these plugs with either the factory tool OR an ordinary wrench or socket.
• Viton O-ring to ensure proper sealing against the engine. This provides a good seal every time
• pre-drilled for safety wire on all six faces.
• includes a rare earth magnet rated at six times the strength of other competing companies.
• We broach the allen key in the drain plug to ensure ultimate strength, this manufacturing process is often over looked because of high tooling cost versus milling a hex with 6 drilled holes on the end. Those 6 holes leave weak points in the hex that are prone to failure with thin wall aluminum.
Fits 851-888 SS750-10100, M600-M1000, S4-S2R-S4R, 748-996, ST2-ST4S, Mh900e, MTS620-1000, HM1100, Sport Classics....
