I'm installing an oil cooler on my M695. I have the bypass spring but I'm not sure which way it goes. Can someone help? I have removed the oil filter threaded bolt. The spring seems to look like a little hand with a "finger" curving around. But, what does this 'finger' cover up? The single hole? The recessed well, piece? Help!!
If you look in the filter cavity you will see a small raised boss. This is where the flat of the bypass spring goes, this keeps the spring from rotating when the filter boss is tightened. When installed correctly, the other hole will be covered.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Ducati Monster Motorcycle Forum
