1 - 12 of 12 Posts
Does anybody know the torque specs for the oil drain plug, oil screen bolt, and the nut that covers the oil screen bolt? Or can you tell me where I can find these specs, other than a Haynes manual which I do not currently have?
I always thought it funny that they include a torque rating for the oil filter.
Then I realized some filters come with a hex nut on them... I think maybe K&N?
For the truly anal retentive, maybe there's a way to rig a strap wrench to a torque wrench?
OR... get a bionic hand/forearm with a digital torque readout!
You're joking right?? Using a torque wrench for an oil drain plug & filter???
no, i don't, but i always use it for the filler cap ;). if you are rich and anal you can buy the genuine Ducati tool that fits the flats on the genuine Ducati oil filter. then you can use your torque wrench 8)
Discussion Starter · #9 ·
I'm glad I did use a torque wrench, because I realized that I would have tightened those suckers down way too much if I was going by feel. 42NM came a lot sooner than I would have thought. Besides, I already had the torque wrench out tonight to install my CC frame sliders - you're not going to tell me I'm crazy for torquing an engine stud now are you?
Thanks for the info guys.
8)
I only use a torque wrench on critical stretch bolt (head, con rods, etc.). I think the Cycle cat motor bolts stretch, but I'm not sure. For the rest of the stuff, it's simple - you want things tight enough that they don't fall off, & loose enough that you don't snap the bolt or strip the threads. Most people tend to tighten bolts up waaay too much.
1 - 12 of 12 Posts
