High speed wobble can be caused by a variety of things other than the suspension, for example a loose head bearing.
Leaking forks are no good, my Duc did that and it was fixed under warranty. If you can upgrade the valves while you're at it, do it. It will greatly improve your high-speed damping (not mph, how fast the shock has to compress when you hit a bump). I'd also get a spring that's rated for my weight if I had to do it over again.
But first of all, I'd set up what I have for my weight and see how it that works. I'm including some links below. Start out setting sag with factory rebound and compression settings and take it from there. Much fiddling and trial-and error is involved, so be warned. I have only begun to comprehend the complexity that is supensions, and it can be frustrating but really rewarding once you start figuring things out.
As to what shock, maybe somebody with first-hand experience will chime in here. Otherwise, if I didn't want to do a lot of the legwork myself, I'd find a knowledgeable suspension tuner in my area and just go with whatever he specializes in.
Good luck,
-R.
The Racers Resource Center
www.racebikesite.com/moto...ations.htm
Circuit 1
www.circuit1.com/circuito...guide.html
Ohlins "The Ultimate Tuning" Manual
www.ohlins.com/pdf/ultima...g_bike.pdf
Fox Shock Setup Manual
www.foxracingshox.com/mot...Manual.pdf
Penske Shock Setup Manual
www.penskeshocks.com/8900...Manual.pdf
Dale Rathwell on Suspension
cgi.motorcycle.com/mo/mcm...hwell.html
Setting up sag - WITH PICTURES!
www.sebimoto-germany.de/e...ttest2.htm
Setting static sag (the rule of thumb method)
www.cornerspeed.net/sus_sag.html
The Club Racer's Guide
venus.13x.com/roadracingw...axclub.htm
The UK Version
www.bemsee.co.uk/tech/setup.html
Factory rules for suspension tuning
www.factorypro.com/tech/S...tting.html
Sport Rider Suspension Tuning Guide-Dialing It In
www.sportrider.com/tech/1...sp_dialin/
Faultline Suspension Tips
Forks:
www.faultlinesuspension.c...sfork.html
Shock:
www.faultlinesuspension.c...shock.html
Technical information for the non-factory rider
www.floridatrailriders.or...chinf1.htm
Tuning Guide - Not just suspension
www.gpsuspension.com/tuningguide.htm
Suspension and Springs
www.tsrltd.com/sag.htm
Fineline Suspension Tuning
www.finelinesuspension.com/sag1.htm
