Refreshed Ohlins DU738 shock with spring (zero miles) ready to install in a '11-'14 M796 or 796 ABS with a new Ohlins 115N spring. This shock will also fit the '09-'13 M1100/1100S and the '12-'13 M1100 EVO with a 130N spring. This shock has adjustable spring preload and rebound damping. The compression damping is not adjustable and fixed internally. The eye to eye length is correct for the single sided swing arm on either 796 or 1100. Spring rate is dependent on intended bike and rider weight. Price does not include shipping from MI.
