I have an odd leak on my 97 M750. It seems that there is a leak coming out of where the neutral sensor is on the back of the engine. When I start the bike in the morning with the choke on, it leaks a few drops onto the exhaust. It looks like it could be brake fluid.
Anyone know what could be causing this?
It seems to be coming from the area in the pic:
Discussion Starter · #2 ·
Upon closer inspection of the fluid, it seems that it is likely oil. I went out for lunch, cleaned the area up so there was none at all and went for a ride. When I came back there was some in the area again. It seems to be seeping out of where the neutral sensor is, pooling in that area and then dripping onto the exhaust. Is this something that is known to leak? I looked around and there doesn't seem to be anything above it that it could be coming from.
