Do you get numb hands more from riding a twin vs a 4 cylinder/v4?
  • Total voters
    11
21 - 27 of 27 Posts
I wanted a lower seat height, but the low seat raised my knees in relation to my hips which was not comfortable.
I also came from a long line of Japanese 4 cylinders (and a BMW inline 4 as well). I expected the twin to be different, and it definitely is. But, no real issues with painful vibration. Those are usually caused by constant high-frequency vibration and long exposure (IE vibration on the highway on a trip). All I get are low frequency vibrations (more oscillations really) at lower RPM just because of the physics of two 600cc cylinders. But, the bike smooths out when underway.
One thing that was a bit of a surprise was how high of an RPM the engine likes to operate at. I was expecting something Harley-esque in torque that would happily burble along in town at low RPM. Not so.
So, a long way of saying maybe you need to run at a higher RPM where the bike is in it's "happy" zone and running smoother. If I let the bike drop into the 3000-4000 RPM range, the mirrors start showing some vibes.
But, there are endless combinations of human bodies and ergonomic situations, so some part of the stock setup may just be bad for you. Fortunately, the aftermarket (and even Ducati) can allow some adjustment.
Yes , agreed. I came from years of riding Harley Davidsons and vintage Triumphs where normal operating range was idle-6000 rpm ( though I did have a few I-4 bikes too).
Then I bought an old carby SS and felt like I was at the IoM and 4000 rpm is when the bike starts to wake up. Then to a Busa and S4RS that want to see the tach needle above 4000 to be happy. It takes an adjustment period. Every motorcycle has an rpm range where it is as smooth as it’s going to get. You need to match your gearing to that rpm range, so that the engine spends most of its time in the “ happy zone”. With my SS, riding mostly back roads, this is 15-41. With my Monster, that would probably work too, but I will wait until I need a new chain/ sprockets to make that change. The Testastretta seems to be smoother than the 2v under 4000 rpm ( maybe it’s the FI) .
Whatever you ride, it helps to learn to keep the engine in the happy zone. The bike is not going to change, you have to change how you ride the bike.
I was out riding home from the GF the other night and thought about this again.
Definitely stay away from 6th gear unless you are going for a speed run. 70mph in sixth is around 4k rpms.
and certainly buzzier than 70mph in 5th which moves you to around 5k rpms. This is where it starts to get smooth and make some power.
Try staying above 5k or even 6k in an entire ride and see if that helps. certainly more fun.
Rex
Yes , I agree. Your fuel mileage will probably suffer, but if you’re worried about mileage that’s probably the wrong bike for you.
21 - 27 of 27 Posts
