1 - 11 of 11 Posts
Super Moderator
On my other Ducati's the answer was to ride more aggressively. Don't be nice when you shift, beat on it a little.
  • Like
Reactions: jeosbor1
I think a rolling neutral works best. Some people report an improvement over time and some don’t.
Use a firm boot and shift like you mean it.
Also helps to wear a Ducati shirt.
Mine seems to be somewhat better with miles. Got it with about 2,400 and have added about 8,000 since.
Maybe my foot has been trained too.
Put my Ducati T shirt yesterday and after 5 hours no natural any more! Not sure how long to T shirt will last wearing it every day. Might help cut down on the number of friends that will talk to me:grin
Super Moderator
If using the logowear app, you need to update with every new release or performance will begin to fade and/or you might notice faster battery depletion. :)
You didn't say when you were getting the neutrals. I would only find them when shifting from 5th to 6th when riding at normal highway speeds. If it is after coming to a stop and attempting to shift into neutral, that method is dead wrong and should be booted from your list of habits. As mentioned in a previous post, always shift into neutral while rolling to a stop. The parts are spinning over each other and the cutaways need to align for you to pull the bits through each other. When stopped you'll be forcing the dogs and detents through the gears. There used to be a problem on earlier bikes of people breaking springs and bending shift forks from shifting into neutral at a dead stop. If you are stopped and cannot easily find neutral, rock the bike back and forth a little while pulling up on the lever.
  • Like
Reactions: 696DCRider
Think I have heard that before, but never remember to try it.
Arta302, you need more Ducati shirts then. :grin
Was between 5 and 6 good to know about trying to shift in to neutral when stopped, I do usually shift to neutral as I am coating to a stop glad to know that is the correct way. When I tried to do that at a stop nothing seemed happy so stopped very early on. Thanks seems to a lot less neutral 5 - 6 shifts now that I am used to what it wants. Thanks to everyone for their suggestions.
That is very interesting. Never heard that before. I mentioned I have more luck when I’m rolling to a stop but I didn’t know exactly why. And I didn’t know I shouldn’t do it at full stop. Good stuff
Discussion Starter #11
Thanks for the support. I will try these methods. I was having trouble while stopped. One time I had a nuetral effect while riding and switching between 5th and 6th gear
1 - 11 of 11 Posts
