I
O OT_Ducati · Guest Joined Jan 1, 1970 · 0 Posts #2 • Apr 2, 2004 put your oil breather plumbing back on,, and see if it goes away.
T TripleDuck · Guest Joined Jan 1, 1970 · 0 Posts #3 • Apr 2, 2004 Vertical cylinder base gasket leak is a very common 01/02 problem. See if your dealer will good will it.
T troyslap · Premium Member Joined Feb 17, 2005 · 1,200 Posts #4 • Apr 2, 2004 I was riding with a guy not long ago with same problem. The oil level was too high when hot.
