my fightered 900ss croaked yesterday .i got it out of the garage fired her up sweet . set off to the petrol staition and 2 miles later she droped on to 1 cylinder. i got her home and the upper cylinder is not playing .i swapped the feeds on the coils to see if the problem moved and it didnt so no pulse out off the digiplex 2s .its only a single pick up so that must be working as the lower cylinder still runs. this is my first duke so any info would be greatly appriciated.
and where would i get a digiplex2s/med442a from anyone have one for sale cheers russ
Swap each ignition parts one at a time: plug, wire, coil, ignition box. After that check the ignition pickup by the flywheel. Everything is easy to change/replace. If you need a new ignition box, try the electronic ones from Checoslovakia - see post it from greenmonster.
