So you havent verified it yet, right? When it works then it will be verified.simonster said:btw, verified to work for all ducati immobilizer-equipped bikes. i bought one, but haven't had a chance to copy mine yet.
But YOU have no FHE yet.simonster said:when i bought mine, a bunch of other buyers e-mailed me to see if mine worked. since then, i've heard from a few, and all have had success on monster, 999, 749, etc.
<sigh> ok. fine. i'll go find some pitbulls and get back to y'all.Ddan said:but are you sure?
[laugh]simonster said:<sigh> ok. fine. i'll go find some pitbulls and get back to y'all.
but when i get back, you folks had BETTER believe me about the keys!!!
Im very familiar with the Ilco key cloner, I used it for may years to reprogram Immobilier keys for Hondas. Sadly you could only use the Ilco T5 blanks. None other than that worked.simonster said:this one isn't so much a miracle. it still only allows you to copy a black key. if you don't have either the red or the black, you're still SOL.
See there you go, it does work as far as the black keys. What about programming new components? ECU? Gauges?lithiumwhite said:with the silca black key, your not really adding keys
your cloning the key you have
so you have a spare
i only had one key
and it was black
so now i have two keys, original black and cloned black, but the bike thinks they are the same key
this is the cheapest way to 'add' or make an extra key and keep the immo function
it worked for me
