You didn't say specifically, but it wouldn't be a bad idea to check the ground wire, I had an older h0nda that as I was cruising down the road, it would suddenly die, then it would backfire like a bazooka, and take off again, I farted around for days with the wiring, and it was a loose ground wire. Good luck!
