Just wondering if the members here can point me in the right direction. I'm stumped. I purchased a 2003 M620ie earlier this year that was running like crap. Originally, I thought a fresh crankcase of oil, clean air filter, new spark plugs, and a new tank of gas would likely cure whatever ailed 'er. Well, it runs better now, but not perfect.
Here's the problem: Anything below about 3,500 rpms and there is almost zero power. To get the bike up and going--especially when a hill is involved--takes a fairly high rev and some clutch slipping to get underway. I'm not a super big guy--about 185 lbs. So I don't think it's a case of FAS (fat @$$ syndrome).
Above 3,500 rpms and with the bike underway, all seems normal. But you still have to hammer the throttle a bit more than you would on a 900.
It's fuel injected, so there aren't any carbs to "play" with. Mechanically, it's fairly stock except for a set of Remus slip-ons. Air box is stock. Battery seems strong--measuring about 12.4 volts with the engine off and almost 14 volts with the engine running. Also, desmogging the bike didn't seem to make the problem any better or worse.
Are these baby Monsters really THIS gutless below 3,500 rpms? Or is this puppy sick? I've only owned 900cc Ducatis until now, and they always had plenty of low-end grunt.
Any input or hints of where to begin looking for this bike's demons are much appreciated in advance.
Thanks,
Marty (long-time DML member)
Thanks,
