The temp sounds OK. What model/year?
temps ok, huh? why would it be spitting fluid (only happened once) and everytime I shut it off the antifreeze gurgles a while...normal?ducpainter said:The temp sounds OK. What model/year?
That vintage SBK had problems with the coolant overflow tank. You might look there.wlsmoku said:many thanks for the manual link, but I couldn't find how to actually adjust the chain on there?
bike is a 1999 996 desmoquattro
wlsmoku said:vintage...ouch hahaha
pardon the ignorance, but what does SBK stand for?
superbike
I'll check out the over flow tank for cracks etc, thank you!
any place you fellas suggest for prchasing a new one if in fact that is my prob?
As I remember they are not expensive from the dealer.
That is exactly what I meant. Just that "style", as opposed to the 749/99.A.Duc.H.Duc. said:by that vintage, he just meant those years, you know, like a fine wine.
my thoughts were to pull the lower fairings off, ride it around a little and let it get hot, then when it does, pull over and look for leaks, etc.hiero said:just fyi, finding an actual visible crack in the overflow tank's pretty difficult. It usually leaks around the center seam and you should see some coolant residue around there.
and yeah, ducpainter's correct, it does take quite a bit to get in there and remove it, you have to remove a lot of stuff...
well, that will get you in the general area where the suspect leak is coming from, but you can't see the seam on the overflow tank without taking the tank off completely, good place to start thoughwlsmoku said:my thoughts were to pull the lower fairings off, ride it around a little and let it get hot, then when it does, pull over and look for leaks, etc.
sounds like replacing it will be a frustrating event [laugh]
ahhh - makes sense....that was my ignorance talkin. well I'll see what I can do. It def sounds like thats the prob thoughhiero said:well, that will get you in the general area where the suspect leak is coming from, but you can't see the seam on the overflow tank without taking the tank off completely, good place to start though
