Will a 120/70-ZR17 fit my 2003 Monster 800.
I have a stock 120/60-VR17. Please let me know.
Thanks.
Thanks.
The stock tire on my S2R was a 120/70 so it should be fine. A 70 is taller than a 60 by 10% of 120mm. So, if the 2003 800 came stock with the 120/60, you might have a clearance problem with the front fender. Measure the distance from the top of the tire to the bottom of the fender, if it's more than 12mm, you should be fine...
Thanks for the reply...
I went from a 60 profile front to a 70 on my M900. No problems at all. One reason I did this is to help balance some suspension modifications I did up front. A taller front tire can counteract (somewhat) dropped triples. Taller tires also help a bit with pot-hole induced bent rims. A taller tire alone should also make the bike turn *slightly* slower and make it more stable (ie- less twitchy).
one thing you'll notice...
if you roll over gravel, you may pick some up and hear a terrible SCRAPE as it pulls through your fender. No big deal, but it can be freaky.
