OBERON Clutch Tool
This Ducati clutch spanner is vital when working on any Ducati Dry Clutch. Designed to fit the Standard 12 tooth basket and the 'aftermarket' 48 tooth version. This spanner holds the center hub and the outer basket to allow removal and replacement of the center hub nut. The pillars on these aluminium clutch assemblies can easily be damaged without the proper holding tool.
Carefully designed and machined to a high finish. Supplied with stainless steel fasteners and fitted with a red rubber handle for perfect grip.
