Bike won't start, lights work, horn too. The Desmodue book says one of my sensors may be fried. Where should I start? Please Help, beautiful weekend awaits me.
check the starter relay.
little box under the seat (usually...depends on the model)
I would also give the battery a full charge and clean and re-attach battery leads
sometimes there is enough juice to run the accessories, and not crank the starter
jeff h
monsterparts.com
More info to add, still not starting. I pulled the headlamp off, disconnecting a wire lume with lots of wires a while back and that may have started this issue. Now I notice that the security light on the cluster no longer blinks, lights come on, neutral light works but none of the digital stuff works. Looks like it may need a reset to the security code, only problem is I only own a key and no card with code, does anyone know the protocol for getting this code???
