Hey guys, Im from Queens NYC but recently moved to Louisville KY with my wife and our 3n Kids. She wanted to move here to be by her family who relocated here from Chicago. So I said, "you wouldn't let me get a bike in NYC, although I grew up on dirt bikes and quads riding all over South Queens and Long Island. So if you want to move I get a bike.
Well I recently came into a little bit of cash and had my first opportunity to get myself a bike. I found on Facebook Marketplace a 99 Monster 750 for $2600 and had like 20K on the speedo. So I figiured I always wanted a Duc and don't want to drop thousands of dollars on a brand new bike bc chances are I may drop it, or worse lay it down. So here I am.
Now after purchasing the bike from a guy around my age or a few years older, mom in my 30s. I noticed on the ride home the bike had a slight wobble when I accelerated, come to find out, I need to do the Fork Seals, bc there seems to be a slight leak a "mechanic" I used informed me. I left him the bike and he did timing belt, tensioners bearings I put 2 new tires on it, as well as spark plugs, oil change, & replaced the air filter. I got the bike back and noticed that from time to time if im on the highway causing and I go to get on it after a bit in 5th if I accelerate a little harder than normal like to get over quickly the bike will begin to shrug and putt and then essentially dies on me and I see this being somewhat of a problem being that it would suck to get hit doing 70-80mph in the left lane and just stop and come to a rolling stop. I've found that if I adjust the choke or "Cold Start Lever," as the manual calls, the bike will rev back up (obviously) sop it won't die but the moment I try to accelerate and give it gas it dies. I thought maybe I was just twisting to much on the throttle and possibly flooding it, but it happened again on me when I was "Babying" the throttle. Any advice on this or if anyone has had similar issues with this it would be greatly appreciated.
My next question I need to replace the chain and sprockets and I ordered all the parts as called for from what I read online and this Ducati manual im putting a 14 in the front and I believe it was a 41 tooth, I ordered for the rear and a 520 x ring 100 link chain, please let me know if this correct and how hard is this job to do? I am pretty mechanically inclined on cars but have never worked on any bikes so I am very green here. Ive seen some laser realigning tool for the back wheel bc I've read it can be an issue if I don't do it right so any advice and or tips for doing this job is appreciated and also, im imagining this tool is not needed...Thoughts?
So today I received my front sprocket and rear sprocket, but still no chain, now how bad would it be if I was to put these 2 sprockets on and reused the old chain for a couple days until the new one comes or should I just not be dumb and be patient and wait? I also noticed when I removed the front sprocket that the 2 bolts that are in the sprocket were both broken off into it and my new sprocket did not come with the bolts or that washer doohickey I seen on a video of a front sprocket removal on a same year 900. out was around the center of the sprocket in the video and my bike didn't have one when I removed the cover to access the sprocket. My new sprocket also came with no bolts, but I went and tried to test fit some bolts and found that a 5mm by .8 pitch fit almost perfectly I figured id buy grade 10's but I do not know how long these bolts need to be. I figured id just use an extractor bit to get them out the old sprocket but I thought this may be faster. So is it imperative I get that washer doohickey thing (probably right? if it was there, it was for a reason, yeah? lol) and does anyone happen to know the lengths of the bolts that go into that front sprocket? My new one did not come
and finally I promise.... my speedo cable looks like it was pinched and cracked at the bottom toward the front tire, does anyone know how to repair this because my speedometer isnt working now, I can buy a new one from the local dealer but they tell me its going to be 7-10 days until the get one in, does anyone know of any on amazon that I could use because none come up for motorcycles it seems, I ask about amazon bc I have like a $200 credit on there and as a father with 3 kids and another due in July im trying to save a few bucks here and there if possible.
So there it is, there's everything I need to know and if anyone can help then your the ****in man so thank you! I look forward to talking with you guys some more and asking more dumbass questions that make you smh lol thanks again.....ill post some more updated pics of the bike shortly
