Hello Fellas & Ladies,
I recently changed out my old CF exhaust system for a new Polished Aluminum Two Brothers System. About two weeks after I did that, the bike started runninglike crap. Sputtering, hesitating, shutting down at red lights, etc. A friend told me that because I changed exhausts, I might need to look at re-jetting the bike. I figured this would only be necessary when going from stock to the new slip-ons. The old Fast By Ferraci's were a straight-thru system just like the new TBR system, so I dont think this would affact things, but maybe one of you guys might be more knowledgeable on the subject.
I have already tried switching fuels, adding Carb cleaner, spraying carb cleaner, changing spark plugs, adding water remover to the fuel, etc. I'm out of options. I NEED Help!!!!
Discussion Starter · #2 ·
changing cans should have little effect.
check for kinked or pinched fuel lines, and gas tank vent lines.
check the fuel pump. read the Bike died on the interstate thread.
I had to replace the Cf cans because the right one got damaged when a coworker backed into & knocked over my bike. I was glad to change them out though-Carbon fiber looks way too tacky for me-it's just that the bikecame with the FBF's installed already. problem is, since the "incident" I've had problem with the fuel delivery system. Either the vacuum cutoff is bad or the fuel pump itself. I've got a horrible sputtering problem.
